#1 2008-02-15 22:59
DaveP
Insert - between words
How can I insert a - between names in a file?
From;
WRS0IC301705-BeltScrewWeighingSystem.doc
To:
WRS0IC301705-Belt-Screw-Weighing-System.doc
#2 2008-02-16 11:31
Re: Insert - between words
Hi Dave,
welcome to the forum big_smile
I would do that with regular expressions. cool
RegEx basics:
Search for any single lower case char       [a-z]
followed by
Search for any single upper case char      [A-Z]
Put () around this search to could refer to the search result later, so use:
Search for any single lower case char       ([a-z])
Search for any single upper case char      ([A-Z])
Later you can use  $n  to use the search result in your replacement.      'n' represents here the number of the n-th  ()-group.
Use this with ReNamer:
So add an new RULE > RegEx
Expression:        ([a-z])([A-Z])
Replace:            $1-$2
The lower and upper cased chars in the RegEx should be enough, but you have to check "[x] case-sensitive" too.
See an pic abou this:
I used here Replace:            $1 - $2
#3 2008-02-16 11:44
To Denis.
this similar script
http://www.den4b.com/forum/viewtopic.php?id=14
gives me an Type mismatch
Error
Preview process has been terminated due to a critical error:
Pascal Script Compile:
[Line 21] Error: Type mismatch        ==>      if IsLetter(FileName[i]) then
OK
(BTW: "Go to line" in Script-Rule works fine)
#4 2008-02-16 15:50
I posted an updated script and the explanation in that topic:
Insert blank space between lowercase and uppercase
So, DaveP, you can use the code from that topic, but simply change the separator, like this:
  Separator = '-';
  I: Integer;
  for I:=WideLength(FileName) downto 2 do
    if IsWideCharAlpha(FileName[i]) then
      if IsWideCharUpper(FileName[i]) and
         IsWideCharLower(FileName[I-1])
      then WideInsert(Separator, FileName, I);
It will work slighly faster than the RegEx rule, but RegEx rule might be more future proof.
#5 2008-02-19 06:15
DaveP
Fantastic!
Stefan's RegEx worked great.
Thanks a bunch!!!!!!!!!!:)
