#1 2008-02-06 18:53
barryvcuk
Review of Shutter
Hope you don't mind but just a quick note to let you know that there is a post here at http://myfreereview.com/ reviewing Shutter
I personally use Shutter and find it very useful.
The My Free Review blog is a new venture for me and I hope that some of the reviews I do in future will bring freeware and portable applications generally to a wider audience in time.
If you have time to look at the review and psot any (constructive smile ) comments that would be great.
Many thanks,
Barry
#2 2008-02-12 16:20
Re: Review of Shutter
Hi, Barry!
Review looks good, and with many details and screenshots which is great smile
The only suggestion I would put is regarding compatibility, which states: XP/2000. A more accurate list would be: 98/ME/2000/XP/2003/Vista. Note that this list will have to be verified for the next version of Shutter, since it could have broken some 98/ME compatibility, temporarily.
By the way, here is a quick link to the post for those who is interested: Shutter - Portable Freeware - Shutdown Tool on Speed
P.S. Good luck with your new site!
#3 2008-02-12 22:21
barryvcuk
Thanks for the info, I have amended the OS list.
Let me know when you release the next version and I will post an update to the review.
Thanks also for your encoragement with my blog.
All the best,
Barry
#4 2008-02-13 15:27
Just to let you know about the neighbouring topic which discusses the upcoming version: Shutter v3 Alpha
