Hi there!
I've got a very helpful suggestion of improvement: a "silent mode" when using the command line feature that runs e.g. a user defined preset automatically and terminates ReNamer after that.
Fiorello
Fiorello, I think you are a bit late. Command line renaming has already been implemented
Have a look at the Help document that comes with ReNamer. Find "Command Line" section.
/rename <preset> <files> - Load preset specified by a preset name or a full path and proceed with Preview and Rename actions. Upon successful Preview and Rename operations, program will close automatically. Otherwise, graphical user interface will become visible and an appropriate error message will be displayed. Paths to files/folders can be appended to the end on this command, and they will be automatically added to the program.
Usage example: "ReNamer.exe" /rename "MyPreset" "C:\Folder"
