#1 2008-01-20 10:47
ozzii
Changelog for Beta releases
Can you add a pinned topic (or a text file into the beta zip) with the changelog of the "beta" release.
This can help to see what is new.
Now, I will have to search for all new topics to see if you post a new beta for a specific problem/feature roll
Possible ?
_________________
#2 2008-01-20 11:52
Re: Changelog for Beta releases
Maybe this helps you, at least as an work around:
You can see new betas on the download page. See the date.
Start this beta ReNamer and look under "HELP > What's new"
If Denis doesn't mind we can open an thread on our own to collect news about betas with links to discussing threads?!?
#3 2008-01-20 12:03
ozzii
For that I use a download manager big_smile
I saw that but I was thinking that this is not updated for each beta hmm
Maybe add a .xx to the version to see the number of the beta and add, for example, into the "What's new"
.03 here is what new newer newer
.02 here is what new newer
.01 here is what new
for a better understanding of the update/news/corrections
_________________
#4 2008-01-20 12:33
I did an start here  http://www.den4b.com/forum/viewtopic.php?id=409
#5 2008-01-20 15:14
ozzii
Stefan wrote:
Thanks a lot for that cool
_________________
#6 2008-01-21 00:05
Ozzi, I store the change log within the programs, in What's New section in About dialog. I don't have any other logs or details about the Beta versions (apart from the date and size in the downloads page), because this would be an extra task for me to take care of. Unfortunately, I cannot afford it time-wise. I'm lucky enough to find some time to even continue working on these tools... sad
Stefan, good man, you are in charge of that topic now smile
#7 2008-01-21 09:16
ozzii
I understand this.
Please, continue to find some time to work onto these GREAT tools wink
_________________
