#1 2008-01-06 10:52
ozzii
Reload when hash type changed
Is there a way to add a button (or maybe F5, or automatic) to reload the same file when a different hash is selected.
I usually use the MD5, but sometimes SHA1, and I can't just change the hash to see the new value.
_________________
#2 2008-01-07 17:36
Re: Reload when hash type changed
If you download this version: HasherBeta.zip - you'll find this feature already implemented wink
#3 2008-01-08 06:11
ozzii
Thanks, I will test this big_smile
_________________
