#1 2008-01-05 13:21
Biggynuff
Message of thanks to Denis
Hi all,
Hope nobody minds, but I just wanted to post a message of thanks for developing one of the most useful pieces of software I've ever used . . .
I have over 500 sets of images, on average around 320 images per set (many thousands of images!)
The problem: images are all sequentially numbered, from 0.jpg, 1.jpg, 2.jpg . . . . all the way to 320.jpg
The task: to rename every image in every directory as necessary to 3 digits, so they display properly in automated slideshows, such as 000.jpg, 001.jpg, 002.jpg etc etc
You can probably imagine the way I was feeling about this . . . the job had to be done, and without any form of automation it would probably have taken months for a team of 3 of us to do in our spare time
The solution: use 'renamer' with the pascal script you supplied on this forum!!!!!
The entire job was done in no time . . . perfectly, without a single problem. Thank you so much
As soon as we have funds in our Pay Pal account we will be donating, thats a sure thing
Well done on such a superb application
Biggy
#2 2008-01-05 19:59
Re: Message of thanks to Denis
Thanks Biggy! You feedback is much appreciated! It's good to hear that smile
#3 2008-02-26 01:24
krtek
I've just discovered Hasher and... it's the same league as ReNamer. Simple (but very nice looking), easy to use, portable and as powerful as you could dream about.  I won't even try other apps doing that job. What's the point? Well done Denis!!!
#4 2008-02-26 08:05
ozzii
Thanks for all your application. Very useful lol
_________________
#5 2008-02-26 22:20
DroidDotBot
renamer is very exciting - (paypal eminent - funds within a week) - may god bless you for your work on this !!!
UK!
#6 2008-02-27 19:16
Helix
Denis:  Re:Renamer
I don't usually take the time to congratulate someone for excellence, but I will make an exception in your case.
This is one of the most versatile and comprehensive utilities I have found in my 30 years of computer administration.
I find this product well engineered and I use it very often particularly in conditioning file names for internet applications.
Thanks to you...
I will be donating to your cause shortly.
#7 2008-02-28 00:56
eR@SeR
ReNamer is best in his class of renaming. There is no such excellent utility on software market for sure! By this occasion I also send a greetings and thankfulness from organisation where I'm member.
Just to note that Hooker is marked as riskware by Kaspersky Lab roll. Probably because of its functionality...
#8 2008-03-02 18:56
