#1 2007-12-04 17:25
ozzii
Remember sort column
is there a way for making that ReNamer remember the sort column between launch.
I always sort the "New name" column, so I would like to have that column sorted when I doing a right click onto a folder.
Any chances tongue
Thanks in advance.
_________________
#2 2008-01-05 19:25
Re: Remember sort column
Yes, a chance wink
I've made that option a long-term option. Find it on the General tab in Settings.
Try: ReNamerBeta.zip
#3 2008-01-05 19:31
Ohh, I didn't pay attention when you said "New Name" column. The thing is... When you preview, the sorting options have to be cancelled (automatically), otherwise you'll loose the original sorting order which could be important for sometimes. But sorting options by any other columns apart from "New Name" and "New Path" will be remembered between sessions.
#4 2008-01-05 21:02
ozzii
Thanks. I will do without that roll
_________________
