Hi Denis
perhaps you could add an "reload the script from disc" -option?
For what? Only for the lazy people:
1. Add RULE PascalScript
2. modify PascalScript in an external editor
3. back in ReNamer > context menu of script >>> choose "Reload"
the same for:
2. modify PascalScript with the internal editor
3. mess up the script
4. choose "Reload"
5. try again to code some nifty thing
ReNamer
Pascal Script Compile:
[Line 23] Error: Invalid number of parameters.
OK
And perhaps line numbers in internals script editor?
I knew that you would as for something like that
As I said in the other post, PascalScript has no memory of what script is using, so reload option is not possible.
About line numbers: I wanted to replace the code editor with a sophisticated script editor component, with line numbers, code highlighting, and all that other sparkling stuff... And I even found a great component for this: SynEdit (http://synedit.sourceforge.net/). But the idea of stuffing ReNamer with loads of 3-rd party components - is not very attractive to me, as this can sooner or later lead to some incompatibilities and other problems.
Instead, I've implemented few other useful (alternative) things:
* Added script drag&drop support for PascalScript code editor;
* Added "Go To" functionality for quick line jump in PascalScript;
Try the latest dev version.
Do you know me that good?
> I wanted to replace the code editor with a sophisticated script editor component, with...
No, you're right. That would be to much. We all have editors enough
Fine thank you
The new help-PDF, BTW, is not that fine for me as user.
If i need help for PascalScript and the PDF opens i have to search for "Script" first.
And i can't add my own notes to the help anymore.
I understand that PDF is not as flexible as HTML-based documents, that's why it took me a while to switch. Yes, the biggest drawback is that I can't open a particular section of the PDF, programmatically. BUT, for me, it is sooooo much easier to maintain and update the document when it is a Word document, which I can easily print as PDF.
By the way, several users came back to me saying that the PDF version is much better, and looks more professional
If you have some notes which you think are important, share them, and I will consider adding them.
Oh, i see. That's important of course!
It's OK
OK.
