#1 2007-11-06 09:23
Saturn2888
Problem with folder insertion
I found out that if you have a folder with images numbered 1-10, then if you are in the folder and select all then drag into ReNamer, it all shows up in order from 1 to 10. If you copy in the folder though, it brings in the files 1, 10, 2, 3, etc...
What is the cause of that and is it possible to fix? Thanks!
#2 2007-11-06 11:44
Re: Problem with folder insertion
Hi saturn
i don't understood.
What do you mean with "copy the folder"?
Where do you see those "1, 10, 2, 3, etc..." ? In WinExplorer?
#3 2007-11-06 13:19
The copy&paste and drag&drop order of files is determined entirely by Windows. Simple things like "where did you start the selection" will determine the order of files for copy&paste and drag&drop operations. Play around with it, and I'm sure you'll find out a way in which you'll get your order to be transferred to ReNamer correctly.
If that doesn't work, then simply use "Natural Sort" option from the settings, and sort the column. wink
#4 2007-11-06 20:22
Saturn2888
I can't find the natural sort option.
#5 2007-11-06 20:39
ReNamer: Settings > General
#6 2007-11-12 11:59
#7 2007-11-12 12:11
Saturn2888
Now I see it! smile I think the version I have at work is too old or something because--
I just checked. At work I have version 4.50 and that option does not exist. Well I'll upgrade ReNamer there. At least, at home I have the newest version.
#8 2007-11-12 12:18
#9 2007-11-12 23:50
Saturn2888
Hmm... Maybe! I'm a little scared of betas now. What's in it that's worth looking at?
#10 2007-11-13 07:54
What's new?
ReNamer Beta 12. Nov. 2007
* Added /list command line parameter to load list of files from text file;
* "Import files" option handles Unicode and UTF8 content (with BOM);
* Added "detect using binary signature" option to the Extension rule;
* Added option to Export/Import list of new names to/from clipboard;
* Export/Import functions have their own button and menu;
* Added InputBox and WideInputBox functions to PascalScript;
* Added FileAppendContent function to PascalScript;
* Analyze dialog will apply only marked rules;
* Updated Russian translit alphabets;
ReNamer 5.10  (12 October 2007)
wink Thanks to Denis for this new features.
You also may read the last topics in the Support and Suggestion forum to see where this new features came from.
For your question above it's enough to load the last stable 5.10, though the beta is stable too.
