#1 2007-09-29 18:39
.hk
Option button "New Project"
I want to say ReNamer program is the best and easy to use. Could you add a buttom where it clear all the rules and files. I been closing the program and reopening it.
#2 2007-09-30 07:14
LawOfNonContradiction
Re: Option button "New Project"
right click on any rule and click:
click on any file:
then right click any file:
^^^ that's the SLOW way, but it helps illustrate some features smile
right click on any rule, Shift-DEL, click any file, CTRL-A, DEL
^^^ that's the fast way.
OR you could check these boxes in options (especially the bottom two)
(clear rules and files on rename)
smile
#3 2007-10-05 12:32
Or even faster, with just two shortcuts:
* Shift+Del - remove all rules (focus on rules table),
* Ctrl+Del - remove all files (focus on files table).
Or as Law said, use the 2 handy option from the settings:
* clear rules lit on rename
* clear files table on rename
Still, I might add this button in the menu, to start New Project, with Ctrl+N key.
#4 2007-10-07 10:51
Added "New Project" menu item to the main menu, with Ctrl+N shortcut! big_smile
Right now, available in the latest development version: ReNamerBeta.zip
