#1 2007-09-29 12:46
Jerryvdl
Doesn't work due to Disabled Performance Counters
Help, I have used CPUMon for a very long time without any problems, but now it doesn't monitor any cpu activity. Instead of the speed en Mb it displays a ?-mark and 0% usage. I've tried a lot to solve the problem, tried to reïnstall it several times, registrycleaning etc. but it didn't solve the problem.
Maybe an inactive service??
#2 2007-10-02 10:22
Re: Doesn't work due to Disabled Performance Counters
Several users have recently discovered this problem. And the problem is in fact in your system, which have the so called performance counters/objects disabled - which blocks CPUMon from reading the cpu usage. One of the users has recently discovered how to manually re-enable those counters, from within registry. I have integrated that solution in the latest development version. On the start-up, if it detects that those counters are disabled, it will ask you to re-enable them.
These are the changes that CPUMon will make to the registry:
HKLM\SYSTEM\CurrentControlSet\Services\PerfOS\Performance:Disable Performance Counters=0
HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Perflib:Disable Performance Counters=0
Try the latest development version: CPUMonBeta.zip
NOTE: CPUMon will not yet work on Vista.
#3 2007-10-02 15:16
Jerryvdl
I've installed the CPUMonBeta, and.......It works, that's really great!
On start up it detected correctly that the counters where disabled.
I'm very happy, I felt kind of handicapped without CPUMon.
Thanks very much for your reply smile
Jerryvdl
#4 2007-10-05 12:51
Yeah, I felt pretty good as well, once this issue was out of the way big_smile
