#1 2007-08-26 14:33
74hct245
How to increment number in the filename
Hello, compliments for your project "ReNamer".
It is possible to sum a value?
Example: I have this file name:
09109101.tif
09109107.tif
09109118.tif
09109121.tif
09109191.tif
I would to sum the value 33 on last three right characters so the result is:
09109134.tif
09109140.tif
09109151.tif
09109154.tif
09109294.tif
P.S.
I do not have understand how to rename only directory names and subdirectory (no file name)
#2 2007-08-26 16:48
Re: How to increment number in the filename
Thanks smile
For your task, use PascalScript rule with the script below.
NOTE: Don't forget to sort by name in the REVERSE order, otherwise you might get collisions when you start renaming.
  ADD = 33;
  Value: Integer;
  Base, Ext: WideString;
function PadLeft(N, Len: Integer): string;
  Result := IntToStr(N);
  while Length(Result) < Len do
    Result := '0'+Result;
  Ext := WideExtractFileExt(FileName)
  Base := WideExtractBaseName(FileName)
  Value := StrToIntDef(Base, -1);
  if Value > 0 then
    Base := PadLeft(Value+ADD, Length(Base));
    FileName := Base + Ext;
#3 2007-08-26 16:50
If you want to rename just directories (folders), open "Filter Settings", and use option "Add folders as files".
#4 2007-08-26 19:07
74hct245
Thanks!!
