Trying to get Shuttter to Mute Master Volume upon PC Shutdown..not quite figuring out how to do this.
Pls advise.
Thanks.
At the moment, Shutter allows only 1 action to be executed upon 1 event. Executing more than 1 action (on 1 or more events) is something that should be in the next release, on which I'm currently working on. There is a workaround though! Shutter can execute a custom command, just before executing an action. In the options, set it to run: C:\Program Files\Shutter\Shutter.exe "Mute Master Volume" (make sure you match the installation path of Shutter). This will mute the master volume just before executing the selected action.
