#1 2007-08-10 16:26
adirving
Renamer: move word three of filename to make it the first word instead
For example I have a file named: adirving example 1234 07-07-07
and I want the new file name to be: 1234 adirving example 07-07-07
Is there a way to do this?
#2 2007-08-10 16:53
Re: Renamer: move word three of filename to make it the first word instead
For the example above, use 1 of the listed below RegEx rules.
1) Find first sequence of digits, and move it to the front of the name:
Expression: ([^\d]*) (\d+) (.*)
Replace: $2 $1 $3
Skip Extension: Yes
2) Make 4 words out of the name, separated with spaces, then move 3-rd word to the front:
Expression: (\S*)\s+(\S*)\s+(\S*)\s+(\S*)
Replace: $3 $1 $2 $4
Skip Extension: Yes
