#1 2006-07-17 13:10
LawOfNonContradiction
ReNamer: Pascal Script: change dec to binary
Would it be possible to have a script find decimal numbers of a length set by the user to binary format?
Say it were  StarGate_922.mpg, and the user chose to search for a 3 digit number.. the result being StarGate_1110011010.mpg.  Would search by number of characters work?  or could I specify using StartsAtPosition for 3 charaters?
:uhoh:
#2 2006-07-17 14:58
Re: ReNamer: Pascal Script: change dec to binary
I'm sure that everything that you can think of is possible, since it's a programming language we are talking about (PascalScript aka Delphi) big_smile But I'm not sure what you are trying to do. Do you want to extract the sequence of digits that is longer than X digits? How are the binary numbers connected to this? Give few examples of what exactly you are trying to achieve...
You will probably need to have a look at these PascalScript functions:
function WideGetChar(const S: WideString; Index: Integer): WideChar;
function IsWideCharDigit(WC: WideChar): Boolean;
P.S. you will also need the newest version: ReNamer.zip
