#1 2007-08-06 11:56
ovo
ReNamer: how to insert the filename at a "right-to-left" position?
I would like to insert "sent_" before the last 3 digits,
To:
"Insert" only got a "left-to-right" position option,
so how could I do this by using other rules,
please help, thanks a lot.
#2 2007-08-06 13:10
Re: ReNamer: how to insert the filename at a "right-to-left" position?
Use PascalScript rule, and put this code:
  RIGHT = 3;
  TEXT = 'sent_';
  Position: Integer;
  Position := WideLength(FileName) - WideLength(
    WideExtractFileExt(FileName)) - RIGHT + 1;
  if Position < 1 then Position := 1;
  WideInsert(TEXT, FileName, Position);
You can change the constants at the top of the script (RIGHT and TEXT).
Alternatively, you could use RegEx rule, to insert text before the last "_" (underscore), but that might get a bit complicated.
#3 2007-08-06 14:16
ovo
Thank you Denis, it works, but will you consider to apply such function to "Insert" for the coming version? It is a lot easier to rename it than using PascalScript. ^_^
#4 2007-08-06 20:25
I will consider it smile
