#1 2025-01-19 20:50
ReNamer 7.7
ReNamer 7.7 has been released.
This update brings several big features frequently requested by our user community. Let's get to it.
  • Rule comments displayed in a dedicated column, no longer hiding rule statements.
  • Rule comments are included in the export of rules to clipboard.
  • Remove Emoji characters via the Clean Up rule.
  • Remove Unicode character ranges via the Strip rule.
Here is a quick demonstration of some of the new features:
The comments column will automatically appear once you add a comment to any rule.
Another major new feature is the Side-by-Side view mode for rules and files panes. You can toggle the view mode in the settings menu.
The new view mode should let you work comfortably with dozens, and even hundreds, of rules loaded at once.
Other changes include:
  • Extend the selections of symbols and brackets in the Strip rule to cover the whole ASCII range.
  • Restore the original behaviour where the first dot at the start of filename is always treated as an extension.
  • Improve the management of presets and the consistency of the preset status.
  • Hold CTRL key when loading a preset in the Presets Manager to automatically close the window.
  • Fix a number of High DPI scaling issues and other inefficiencies.
  • Updated language files: French, Russian, Traditional Chinese, Turkish.
For more details see the full changelog between versions 7.6 and 7.7.
