#1 2025-01-18 14:19
Lauraq
Delete all if there are no numbers...
Hi smile
I have this problem, I'm trying to organize my song collection.
Many are in this format:
03 - title.flac
others are:
author - title.flac
the delimiter is always " - "
Is it possible to have a command that intervenes by eliminating the author and that does not touch anything where there are numbers? So have
03 - title.flac
and
title.flac
Thanks smile
#2 2025-01-18 16:31
Re: Delete all if there are no numbers...
You can use the Regular Expressions rule, replacing expression "\A\D+\s+-\s+" with "" (empty).
\A matches the beginning of the text.
\D+ matches a sequence of non-numeric characters.
\s+ matches a sequence of white spaces.
It might be time for you to start learning Regular Expressions wink
#3 2025-01-18 18:33
Lauraq
Fantastic  smile
