#1 2007-07-18 08:46
oldbell
new suggest.(multi thread, multi action, multi target, multi interval)
* one task example
1. append file action (file copy, file move, file delete) / per file
    (now default action is just move)
2. append setting target folder ( use meta tags, special string (date, time, ... ) for target folder )
   ex) set target folder
           target folder = 'c:\target\{yyyymmdd}\' + filename;
      => target folder = 'c:\target\20070718\sourcefilename'
3.  add multi target folder ( for multi file copy )
     3.1 ex) target folder 1 = 'c:\backup\{yyyymmdd}\'      / file action = copy
               target folder 2 = 'c:\transfer\{mmdd}\'  / file action = move
4. add action interval settting ( for schedule action )
    interval time := 10 ; ( 10 second )
5. reuse rules
    customer save each rule and reuse ;
* set multi task ; ( use multi thread )
#2 2007-07-26 11:16
Re: new suggest.(multi thread, multi action, multi target, multi interval)
1. append file action (file copy, file move, file delete) / per file (now default action is just move)
"File Copy" is useful, and is currently on my "to do" list, but I don't see any use for "file delete" action??
That's already possible, simply Insert the new path in front of the names.
For example: Insert "C:\New Folder\" as prefix, and you'll see the result.
4. add action interval setting ( for schedule action )
Latest development version supports command line renaming, check out the help file. You can write a small *.BAT script with the desired interval.
5. reuse rules
There are presets for saving and reusing rules.
Don't see any need for it, because you can open as many instances of ReNamer as you want.
