#1 2024-09-20 11:43
tplatero
Suggestions - Add a "Comment" column
I mean to show the comment in a diferent column insted of change the instruction for the comment. In my case this if because i have 22 regex rules and when i need to change one of them, I have to spend some time analyzing which of them it is because some of them are very long and I don't remember what some of them do, in fact I have made a spreadsheet with the comments and I would like the comments to be visible at the same time as the instructions.
#2 2024-09-23 15:51
Re: Suggestions - Add a "Comment" column
Thank you for the suggestion.
This has been requested quite a few times already, so it's high up on our priority list to get implemented.
#3 2024-10-08 17:26
This feature has been implemented in v7.6.0.1 Beta.
A separate "Comment" column will be displayed once you add a comment to any renaming rule.
Please try the latest development version and let us know how it goes.
