#1 2024-08-08 02:48
Maga999
Change the case before or after certain character
Hello!
I need help with regular expression code for this :-
The text before the following special characters in the file name  [-] OR [–] OR [—] >>> Capitalize Every Word
The text after the following special characters in the file name  [-] OR [–] OR [—] >>> Sentence case
For Example:
Input:
the last samurai – the way of the sword.mp3
The Result:
The Last Samurai – The way of the sword.mp3
Hope you help
Thanks!
smile
#2 2024-08-08 14:16
Re: Change the case before or after certain character
How about a Pascal Script rule instead?
  BaseName, Delimeter: WideString;
  DelimeterPosition: Integer;
  Positions: TIntegerArray;
  Matches: TWideStringArray;
  if FindRegEx(BaseName, '\s+(-|–|—)\s+', False, Positions, Matches) > 0 then
    Delimeter := Matches[0];
    DelimeterPosition := Positions[0];
    BaseName := WideCaseCapitalize(Copy(BaseName, 1, DelimeterPosition - 1)) + Delimeter +
      WideCaseSentence(Copy(BaseName, DelimeterPosition + Length(Delimeter), Length(BaseName)));
    FileName := BaseName + WideExtractFileExt(FileName);
This script will handle all three delimiters that you mentioned: "-" (U+002D), "–" (U+2013) and "—" (U+2014).
#3 2024-08-08 17:48
Maga999
Works Perfectly!
Thank you so much smile
#4 2024-08-08 21:24
Maga999
I forget something..
If there's ( ) in the file name i want the text inside it to be sentence case also
Example:
Input:
the last samurai – the way of the sword (VERSION 01).mp3
The Result:
The Last Samurai – The way of the sword (Version 01).mp3
Can you edit the script please ?
#5 2024-08-10 22:35
This script will also handle the bracketed content at the end of the filename.
  BaseName, Match: WideString;
  Position: Integer;
    Match := Matches[0];
    BaseName := WideCaseCapitalize(Copy(BaseName, 1, Position - 1)) + Match +
      WideCaseSentence(Copy(BaseName, Position + Length(Match), Length(BaseName)));
    if FindRegEx(BaseName, '\(.*?\)\Z', False, Positions, Matches) > 0 then
      BaseName := Copy(BaseName, 1, Position - 1) +
        WideCaseSentence(Copy(BaseName, Position, Length(BaseName)));
#6 2024-08-11 17:43
Maga999
Excellent!
smile
