#1 2024-08-03 14:03
anemone
need help with changing yyyy-mm-dd hh:nn:ss to yyyy-mm-dd +rearranging
I tried to reformat the date from yyyy-mm-dd hh:nn:ss to yyyy-mm-dd but it didn't work
File name:
ShouldHaveCat-[2024-07-28 07ː47ː19 UTC]-1817466855679820101_3
What i want:
2024-07-28-ShouldHaveCat-1817466855679820101_3
#2 2024-08-04 08:41
blackvoid
Re: need help with changing yyyy-mm-dd hh:nn:ss to yyyy-mm-dd +rearranging
I don't know what you mean by reformat date but this should work.
Add rule, choose 'Regular Expressions'.
Add the following :
Expression : ^(.+)-\[(\d{4}-\d{2}-\d{2}).*\]-(.+)$
Replace : $2-$1-$3
Skip Extension : make sure its ticked.
Save rule.
#3 2024-08-05 00:20
File name: ShouldHaveCat-[2024-07-28 07ː47ː19 UTC]-1817466855679820101_3
It looks like the reason why the Reformat Date rule does not work in your example is because it contains an unusual time separator character “ː” (U+02D0) known as "Modifier Letter Triangular Colon", but the source format in the rule uses a common colon character “:” (U+003A).
Despite looking virtually same in most fonts, they are different characters.
The solution is simple. You need to adjust the source date/time pattern in the rule to use the unusual colon symbol, as follows:
yyyy-mm-dd hhːnnːss
Instead of:
yyy-mm-dd hh:nn:ss
