#1 2024-04-29 00:17
somebody2978
Translate file names from one language to another
Translate file names from one language to another. Example, from Korean to English. It's possible?
#2 2024-04-29 23:47
Re: Translate file names from one language to another
You could try something like this:
  1. Add your files to ReNamer,
  2. Export the list of new names to clipboard,
  3. Paste them into a translator,
  4. Copy the translated file names,
  5. Import the list of new names from clipboard back into ReNamer,
  6. Rename.
See the Export menu for the relevant options.
There is also the Translit rule, in case you wanted to transliterate the names instead of translating.
#3 2024-05-01 23:01
somebody2978
  6. Rename.
Great! It worked very well! Thank you!
