#1 2007-06-27 04:30
werich
License issue of Renamer 4.65
Dear Denis
    I would like to use Renamer 4.65 for commercial purpose. I can't found any license statement in the Renamer 4.65,  but you declares that this work is licensed under a  Creative Commons License on your website.
    Is it right if i use Renamer 4.65 for commercial purpose? what could i do if not?
    I would appreciate you if got your reply.
#2 2007-06-28 07:24
Re: License issue of Renamer 4.65
License states that anyone can use my programs as long as it is for non-commercial purposes. Other two points in the license are: attribution and no derivative works - which I think speak for them-selves.
So, if you use ReNamer for your-self at home - it is absolutely fine. smile
But, if you are working for commercial organization, you would need to contact me to obtain a commercial license.
#3 2011-05-05 21:01
SHaynes
Hoping this post on an old issue will be noticed!
I, too, wish to use Renamer commercially. By that I mean I will be the only person in a large organization using it -- so it is for a single site license. The suggested price for a single license is 10 Euro, correct?  Please tell me how to make this arrangement so I can be compliant. Thank you.
SHaynes
#4 2011-05-05 23:54
