#1 2024-01-30 19:02
Lauraq
Capitalize every word in brackets (...)
Hi smile
Could you tell me how to capitalize all the words inside the brackets?
And then, if it's not too difficult, if it were possible to lowercase the word "and" and "feat" always inside the brackets
for example
15 - Madonna - Like a virgin _ hollywood (feat christina aguilera and britney spears)
to
15 - Madonna - Like a virgin _ hollywood (feat Christina Aguilera and Britney Spears)
Thank you so much smile
#2 2024-02-06 18:54
Re: Capitalize every word in brackets (...)
You can use this script in the Pascal Script rule to capitalize all words inside of round brackets:
  I, NumMatches, MatchLength: Integer;
  Positions: TIntegerArray;
  Matches: TWideStringArray;
  NumMatches := FindRegEx(FileName, '\(.*?\)', False, Positions, Matches);
  for I := NumMatches-1 downto 0 do
    Delete(FileName, Positions[I], Length(Matches[I]));
    Insert(WideCaseCapitalize(Matches[I]), FileName, Positions[I]);
Then, you can use the Case rule to lower case the desired words like "and" and "feat" via the force case option.
We also plan to add a more general mechanism that will allow users to apply renaming rules to a selected part only.
#3 2024-02-06 22:42
Lauraq
fantastic, thanks smile
