#1 2024-01-18 18:08
dominusdj
Rearrange difficult file name
Hello....I'm trying in every way to rename many files but I can't find the right setting.
I have many files with different lengths and I need to create a rule that after the double character "__" up to the extension (excluding) it must be moved after the character ")"
I'll give you an example
File name:
PCC Y.17.59 (17,5db-0,62dt-SGP-50-60Hz-WOOW)_test123__MDFY.17.5-59-00.xls
Becomes:
PCC Y.17.59 (17,5db-0,62dt-SGP-50-60Hz-WOOW)__MDFY.17.5-59-00_test123.xls
Can anyone kindly help me?
Thanks a lot
#2 2024-01-18 18:47
Re: Rearrange difficult file name
You can achieve this with a Rearrange rule.
Split using an exact pattern of delimiters: ")_|__"
New pattern: "$1)__$3_$2"
(exclude the quote marks)
#3 2024-01-19 11:13
dominusdj
Thanks a lot, works!!!
