#1 2024-01-09 20:21
autryld
Delimiter from $n to end of filename
This is great renaming tool. It renames using techniques the other tool doesn't. Thanks to the developers! There's just one thing I can't figure out (so far smile ).
I would like to use space as the delimiter but only for the first 3 delimited parts. I want to ignore the remaining positions on rewrite.  I have been unable to find or figure out how it might be done.  The alternative would be to use awk in Linux but this seems much easier with ReNamer  if only I could find out how to ignore positions n-$ (n through the end of the filename. Ignoring the extension of course.)
Here is a dummy file name.
2001-12-09 JohnSmith #299 Murder Done Wrong & Knights at Night.mp3
Exampe target filename:
#299 2001-12-09 JohnSmith - Murder Done Wrong & Knights at Night.mp3
Thanks,
Larry
#2 2024-01-11 00:42
Re: Delimiter from $n to end of filename
There are a few ways of achieving this:
A) Rearrange rule: Split by exact pattern of delimiters " #| ", new pattern "#$2 $1 - $3".
B) Regular Expressions rule: Replace expression "\A(.+?)\s+(\#\d+)" with pattern "$2 $1 -".
C) Pascal Script rule: This one would be more complex, so let's keep this as the last resort.
#3 2024-01-15 05:24
autryld
Thank you.
The Regular Expression rule worked! I have some experience with sed and vi but only for straightforward string replacement.  Thanks!
The Rearrange rule did not seem to work, unfortunately.
Thanks,
Larry
#4 2024-01-16 14:28
You might have missed the required spaces around the split pattern " #| ".
Here is the demo of it working for your example filename:
#5 2024-01-30 19:48
autryld
https://www.den4b.com/forum/img/members … e-2994.png
That's exactly what happened. Thanks for pointing that out.
Larry
