#1 2007-06-21 14:34
verbor
Add files/folders broken in Beta version
Hi
Add files/folders doesn't work in the beta version
Regards
#2 2007-06-22 16:38
Re: Add files/folders broken in Beta version
A small mistake with the new "Filter Masks" feature: empty mask would not match any files/folders.
It is now fixed, try downloading again: ReNamerBeta.zip
Anyway, thanks for reporting! smile
