in export dropdown i´m missing s/th like "export filename and new filename", which would be almost the same as "export file paths and new names" but without the path.
Is there a way to do this without an additional step in an editor ( search&replace )
thx Olli
You can use the "Export all columns to clipboard" option, found in the Export menu about the file table.
You can also toggle visible columns via the table header context menu.
Ok, but then i would have some additional steps.
1. toggle columns to invisible which i don´t need to export
2. export to clipboard
3. open editor, paste clipboard, save file
4. go back to renamer and toggle columns back to visible
What about s/th like "Export columns..." and then be able to select the (visble) columns that should be exported (to csv file).
I don´t know if this is a lot of work for you, but that would be the most flexible way i guess.
Olli
