#1 2023-09-15 01:08
vanon
Suggestions - One Instance, Hide Algorithms
I would just like to suggest ("vote" for) two options for Hasher. They would make it more pleasant to use, in my opinion. I would appreciate if they would be considered, or perhaps they're already possible somehow.
1. Option to "use only one instance". Easier to use with "Send to" menu (and related like Custom Context Menu app). Currently it will send each file to their own instance. Workaround is fine but can be annoying (send only once, then drag further files to window).
2. Option to "hide hashing algorithm". I only use a couple most of the time (CRC32, SHA256), the rest always remain empty and clutter the UI.
