#1 2023-07-20 05:52
Xbon
Subtract a second from time in the filename
Been a while...
Anyway hoping i can do this to save me some time..
Is there a  way to subtract a second from a named file for example
i have my flac music files named like this
Mud - 01 - Dyna-Mite (3.00)
the duration added at the end by a tag program, however some of the times the duration is slightly wrong it is always a second longer when compared to the log of the file so for example the log of that file is (2.59)
is there a way i could reduce that duration by a second so i could simply drag a load of files and have renamer pro rename them minus the 1 second
ie Mud - 01 - Dyna-Mite (3.00)
would be
Mud - 01 - Dyna-Mite (2.59)
Thanks for the help.
#2 2023-07-21 21:44
Re: Subtract a second from time in the filename
This is actually a great task for the Reformat Date rule.
Rule configuration:
  • Find format: n.ss
  • Convert to format: n.ss
  • Match as whole words only: YES
  • Skip extension: (as you wish)
  • Adjust time by: -1 seconds
#3 2023-07-24 10:22
Wonderful solution.
Works fine for me.
Now I understand better how this works (match the wanted by using fitting "Find format" and "Convert to format")
