#1 2023-07-19 18:57
FranciscoOG
Rearrange or Replace? Parts of words in the filename
i've looking up the rearrange and replace section of the documentation, but i dont find any possibility for what i need
example:
initial name : sequenceofcharacternumber1 sequenceofcharacternumber2 sequenceofcharacternumber3.XXX
result : ssequencsequenceofwordnumber3.XXX
concrete example :
initial name : "jonasson wilfriddssen CERT01.pfx"
needed name: "jwilfridsCERT01.pfx"
so i need to
1)replace the first sequence of characters by the first character of the first sequence of characters
2)replace the second sequence of characters by the first 7 characters of the second sequence of characters
3) leave the third sequence of characters untouched
4) remove all spaces ( i know how to do that part )
ps: the sequence words can go from 3 to to 15 characters long
examples :
bobdylan thundbergmohammed CERT01.pfx
results:bthundberg
thanks in advance,
regards
#2 2023-07-19 21:29
Re: Rearrange or Replace? Parts of words in the filename
That is exactly why the Regular Expressions were invented.
Add a Regular Expressions rule with the following configuration.
Expression:
([^\s])[^\s]*\s+([^\s]{1,7})[^\s]*\s+(.+)
Replace:
$1$2$3
This should convert "jonasson wilfriddssen CERT01.pfx" to "jwilfridCERT01.pfx", as you described.
#3 2023-07-19 21:40
FranciscoOG
<3 thanks a lot mate <3 i will look right into it
