#1 2007-06-04 23:36
sirjack
ReNamer "Files mask" bug
Hello.
The "Files mask" option on the top right pane when Adding Folders doesn't work: it is ignored.
I've put the *.jpg string in the text box but ALL files were added in the list (and not the JPGs only), so i had to manually remove or uncheck the unwanted files before start the rename operation.
This bug was not in the release 4.17 but surely in the release 4.60 and in current ones (4.65 and BETA).
Thanks and greetings.
SirJack
#2 2007-06-13 16:00
Re: ReNamer "Files mask" bug
Sorry for such a late reply, I'm on vacations at the moment.
Thank you for reporting this problem! The latest development version has this problem fixed. I removed that "files mask" option from the browse dialog, and added "masks" option to the filter settings. This new option will have a wider control, passing ALL added files/folders through those masks.
Try it, and tell me how it goes, ok?
ReNamerBeta.zip
#3 2007-07-13 17:23
sirjack
Thanks!
The new version seems to work fine now.
Bye.
SirJack.
