Licensed and satisfied Pro user since 2017!
But I cannot figure out how to create a rule that inserts the current content of clipboard.
Example:
Filename BEFORE renaming:
123_file-example.txt
Last text copied to clipboard:
simple_
Filename AFTER renaming:
123_simple_file-example.txt
Thanks in advance!
At the moment the clipboard content can be accessed only via the Pascal Script rule.
The script below will achieve what you have described, using Regular Repressions for handling the insertion of clipboard content:
FileName := ReplaceRegEx(
FileName, // Input
'\A(\d+)_', // Find
'$1_' + GetClipboardText, // Replace
True, True); // Options
It might be a good idea to implement a meta tag for a more convenient access to the clipboard content via other renaming rules.
