#1 2023-05-06 11:44
Rascom
How to rename a file with text that is inside brackets ?
Hello. How to rename a file with text that is inside brackets ?
Example:
"File_Name [ABC-123].txt"
or
"File_Name (ABC-123).txt" needs to become:
"ABC-123.txt"
Brackets can be anywhere in file name.
#2 2023-05-06 22:56
Re: How to rename a file with text that is inside brackets ?
It can be done in few different ways.
For example, using these Regular Expression rules:
1) Replace expression ".*?\((.*?)\).*" with "$1" (skip extension)
2) Replace expression ".*?\[(.*?)\].*" with "$1" (skip extension)
Example input filenames:
File_Name (ABC-456).txt
Example output filenames:
ABC-123.txt
ABC-456.txt
