#1 2023-02-01 19:46
fullerm
Remove last extension
I have many pdfs with extensions containing random  characters tacked on the end. e.g. file1.pdf.2_0x323256 How can I remove just the last part?
#2 2023-02-01 20:40
Re: Remove last extension
Add an Extension rule with an empty new extension.
Note that it will remove the last extension even if it is the only extension in the filename.
