#1 2023-01-31 21:32
ErikT
Updating File Name From Higher Level Path Info
I have many file paths of the type below:
I would like to rename the files in the lowest level folder to this:
I can't seem to find the "magical incantation" to make this work.  Closest things I could find was using Rearrange create descendant folders but that's not particularly helpful.
UPDATE:
Using the "Insert Meta Tag" button on the Insert Rule and selecting "File_FolderName" inserts the name of the next highest level folder into the target.
#2 2023-02-01 08:09
Re: Updating File Name From Higher Level Path Info
Hi and welcome.
Looks like you have solved that on your own, right?
#3 2023-02-01 12:03
ErikT
I figured it out right after I posted smile   I updated the post so that perhaps it would help someone else in the future.
#4 2023-02-01 17:29
Great.
Thank you for that.
Enjoy ReNaming.
#5 2023-04-20 03:20
adiosdonut
I'm looking for something similar, but rather than insert the name of the lowest level folder, I want to insert the name of the folder one level up:
#6 2023-04-20 10:52
See the answer provided in a separate thread: How to add name of folder 2 levels up as prefix?
