#1 2023-01-20 13:29
Tori
How to make a rule for Rearrange
I have files named date.month.year ххх.ext How do I write in configuration to rearrange to year.month.date xxx.ext? Tried to figure out the configuration according to help file, but nothing works.
#2 2023-01-20 19:18
Re: How to make a rule for Rearrange
Hi and welcome, Tori.
You may want to check out the Reformat Date rule first?
https://www.den4b.com/wiki/ReNamer:Rules:ReformatDate
#3 2023-01-21 10:40
As for the Rearrange rule, you can use the following configuration:
Split by exact pattern of delimiters: ".|.| "
New pattern: "$3.$2.$1 $4"
Skip extension: YES
(Exclude the quote marks)
#4 2023-01-22 16:57
Tori
Thank you so much, I missed this variant of the rule. I corrected the date in all the files.
#5 2023-01-22 17:03
Tori
Skip extension: YES
Alas, it didn't work out. I had the file name "13.10.2020 1.doc", created a rule by copying what You wrote, the result was the file name is "2020 1.10.13 .doc".
#6 2023-01-23 12:52
jogiwer
Looks like you have missed the blank at the end of the delimiters here. Resulting in:
  1. "13"
  2. "10"
  3. "2020 1"
  4. ""
This got rearranged as
"2020 1"."10"."13" ""
#7 2023-01-28 21:12
Tori
Here I am again sad
I can't figure out how to correctly rearrange titles. Let's say I have a file with a name of four words (X X X X_01).mp4 and a number at the end. I need to put the number and _ at the beginning, and leave the rest unchanged. Tried all the options, it does not work.
Pleeease, help!
#8 2023-01-28 21:57
x x x x_01.ext
xx xxx x x abc def_02.ext
_01 x x x x.ext
_02 xx xxx x x abc def.ext
Try
1) Rearrange: Split by delimiters "_", New pattern "_$2  $1" (skip extension)
Explanation:
The $1 "container" capture all till the underscore
The $2 gets all after the underscore
The underscore, used as delimiter, is removed by the rule.
So in the result use the $1 and $2 "container" in the wanted order
and just add the underscore and need space manually by hand.
#9 2023-01-28 22:19
Tori
Thank you so much!
I think I realized my mistake, I thought each word was a separate container.
