#1 2022-11-16 16:26
roosterdog22
Serialize Question
I have a 250 thousand images I'm trying to rename in a certain way but I can't seem to achieve it.
This is what I'm going for:
Set#|Shoot#|Image#
I'm obviously not trying to do all of them at once but rather set by set and what's stopping me is the shoot number repeating all the way to the end and not incrementing by 1 at the change of the shoot folder.
#2 2022-11-16 17:13
jogiwer
Re: Serialize Question
Hi roosterdog22,
here are some essential details missing.
Do you want to do the sequencing without inspecting filename and folders? Or do some or all numbers exist inside the path of the files?
#3 2022-11-17 00:26
roosterdog22
jogiwer wrote:
Hi roosterdog22,
They are all serialized.
I just want to make it easier for me to identify where I pulled a file from when I use it in a project and to also avoid any naming conflicts.
Thanks for asking.
#4 2022-11-19 18:59
Can you provide some examples of input and desired output filenames?
#5 2022-11-19 20:01
roosterdog22
The screenshot is an example of what I'm trying to achieve however if I were to add multiple folders with varying amounts of images then it doesn't work.
What I need it to do (the 4th rule which is highlighted) is repeat to the end and then increment by 1 after the folder changes and there doesn't appear to be an option for that?
An example of the folder structure:
Set_001
	Shoot_001
	Shoot_002
	Shoot_003
Set_002
	Shoot_001
	Shoot_002
	Shoot_003
Set_003
	Shoot_001
	Shoot_002
	Shoot_003
Each shoot can range anywhere from 50-100 images.
#6 2022-11-20 19:15
It will be a lot simpler to insert parent folder names into the file names.
For example, converting "Set_001\Shoot_002\003.jpg" to "Set_001\Shoot_002\Set_001_Shoot_002_003.jpg".
Then you can delete the unnecessary parts like "Set_" and "Shoot_" to leave you with just "Set_001\Shoot_002\001_002_003.jpg".
A pascal script attached below will insert the two parent folder names:
  ParentFolder1, ParentFolder2: WideString;
  ParentFolder1 := WideExtractFileDir(FilePath);
  ParentFolder2 := WideExtractFileDir(ParentFolder1);
  ParentFolder1 := WideExtractFileName(ParentFolder1);
  ParentFolder2 := WideExtractFileName(ParentFolder2);
  FileName := ParentFolder2 + '_' + ParentFolder1 + '_' + FileName;
#7 2022-11-20 20:30
roosterdog22
Amazing...
Thank you so much for this!
