#1 2022-08-19 20:46
Togolen8
Can ReNamer remember its window position?
When I open the program it defaults to a small window in the middle of my screen every time. Is there a way to set it up the way I want it to open?
Thanks.
#2 2022-08-24 13:39
Re: Can ReNamer remember its window position?
Renamer will store his settings in a file called "Settings.ini".
Be sure you have write access to that file.
There is also this article with some information >>> https://www.den4b.com/wiki/Application_Data_Storage
#3 2022-08-26 09:40
Enable the "Remember position and size of major windows" option, found in the Settings, in the General tab.
#4 2022-08-27 17:47
Togolen8
Wow! big_smile
Thanks!
