#1 2022-07-09 16:08
visusys
Global matching with Regex?
How can I do a global match as outlined here?
For example (simple hypothetical) if I wanted to strip all white space from part of a string:
https://stackoverflow.com/questions/180 … hitespaces
Any help greatly appreciated.
#2 2022-07-09 19:15
Re: Global matching with Regex?
"    tushar is a good      boy     "
"tushar is a good boy"
You can use the CleanUp Rule with "Fix spaces"
https://www.den4b.com/wiki/ReNamer:Rules:CleanUp
If you prefer RegEx:
You can regex search for "\s\s+" and replace by one single space.
and to get
To remove leading and trailing spaces also, additionally search for "^\s+|\s+$" and replace with nothing in an second RegEx rule.
https://www.den4b.com/wiki/ReNamer:Rules:RegEx
And now altogether with only one RegEx rule:
Search for "^\s+|\s+$|(\s)\s+" and replace with "$1"
That is  "^\s+  |  \s+$  |  (\s)\s+"
For more complex rules we would use PascalScript.
