#1 2022-06-06 23:03
oem
Dynamic Multidimensional Arrays in Pascal
type
  MultiWideStringArray = array of array of WideString;
  EnglishSongNameArray: MultiWideStringArray;
SetLength(EnglishSongNameArray, 5, 5);
  // Add your code here
  // Press Ctrl+Space for code completion
  // Hold Shift when loading a script to insert it inline
Doesnt seem to work
#2 2022-06-07 00:17
Re: Dynamic Multidimensional Arrays in Pascal
I think you will need to store a multidimensional array as a single dimensional array, with a simple remapping of cell coordinates.
The script below will set your new names to "Hello World", but using a two dimensional array to store the words.
type
  TTable = record
    Rows: Integer;
    Columns: Integer;
    Data: array of WideString;
function CreateTable(Rows, Columns: Integer): TTable;
  Result.Rows := Rows;
  Result.Columns := Columns;
  SetLength(Result.Data, Rows * Columns);
procedure SetTable(var Table: TTable; const Row, Column: Integer; const Value: WideString);
  Index: Integer;
  Index := Row * Table.Rows + Column;
  Table.Data[Index] := Value;
function GetTable(const Table: TTable; const Row, Column: Integer): WideString;
  Index: Integer;
  Result := Table.Data[Index];
  Table: TTable;
  Table := CreateTable(2,3);
  SetTable(Table, 0, 0, 'Hello');
  SetTable(Table, 1, 2, 'World');
  FileName := GetTable(Table, 0, 0) + ' ' + GetTable(Table, 1, 2);
