#1 2022-04-12 06:02
Crucito
Case renaming "UPPER Capitalized - UPPER"
I have:
Nolan CHRISTOPHER - Dunkerque 17 ultima Version
I want:
NOLAN Christopher - DUNKERQUE 17 Ultima version
How can I do that using "Force case for fragments"
#2 2022-04-12 18:29
Re: Case renaming "UPPER Capitalized - UPPER"
Why this particular option?
I think there are better options available, like Replace or Regular Expressions rules, depending on the pattern of other filenames.
Having more examples will help design the right rules.
#3 2022-04-12 19:35
Crucito
Thanks.
I thought it was of easy use, my abilities are near to null. This are other examples of what I have:
1. Nolan CHRISTOPHER - Dunkerque 17
2. GUERRA CIRO - EL ABRAZO de la serpiente
3. REED carol - EL ÍDOLO Caido
4. Reed Carol - la agonia y el extasis
5. REED CAROL - Nuestro hombre en La Habana
6. RENAUD CHRIS - LORAX, EN
7. SAINTE-LUCE CLAUDIA - los insolitos peces gato
8. RENAUD CHRIS - el LORAX 2012
And this are what I want:
1. NOLAN Christopher - DUNKERQUE 17
2. GUERRA Ciro - EL ABRAZO DE LA SERPIENTE
3. REED Carol - EL ÍDOLO CAIDO
4. REED Carol - LA AGONIA Y EL EXTASIS
5. REED Carol - NUESTRO HOMBRE EN LA HABANA
7. SAINTE-LUCE Claudia - LOS INSOLITOS PECES GATO
8. RENAUD Chris - EL LORAX 2012
If in the case rule "Force case for fragments" what is string?:
Nolan,CHRISTOPHER, - ,Dunkerque, 17,
#4 2022-04-12 21:58
You can do this with a Regular Expressions rule with the following configuration:
Expression: \A([\w\-]+)\s+(\w)(.+?)\s+-\s+(.*)\Z
Replace: \U$1 \u$2\L$3 - \U$4
Explanation of all these magic characters is available in the User Manual.
Input filenames:
Output filenames:
RENAUD Chris - LORAX, EN
#5 2022-04-13 00:39
Crucito
I will try and I hope learn. But primarily thanks to you.
