#1 2022-04-01 13:40
mnatali
Shorten name from 143 to 100 chars/signs
i need your help:
i'd like to shorten the name of files in this way: i have to find all the names of files that are longer of 143 characters and reduce it to 100..is it possible?
#2 2022-04-01 19:50
Re: Shorten name from 143 to 100 chars/signs
Yes, it is possible.
Open the Files menu or right-click on the files table, Select menu, Select by Name Length.
The are many different ways for reducing the filename length, it all depends on which parts you want to drop.
For example, you could simply truncate the end of the filename via the Delete rule from position 101 and until the end.
