#1 2022-02-26 02:59
nkormanik
"Undo Renaming" as a Preset link that can be double-clicked on desktop
As of the present, user can change the name of a file in ReNamer, and, if user changes his/her mind, can "Undo Renaming" from the program menu.  Presto, original filename is restored.
User can create a desktop link to do this renaming.
I would like to request that "Undo Renaming" also be included as an optional desktop link.
So, say, two double-clickable links on desktop.
#1.  Rename a file in some folder.
#2.  Restore that file to its original name.
This functionality would be much appreciated.
Thanks!
Nicholas Kormanik
#2 2022-03-06 20:38
Re: "Undo Renaming" as a Preset link that can be double-clicked on desktop
You can achieve the same effect by exporting file paths and undo paths after renaming in a form of a CSV file, and then importing them later as file paths and new names. You will find the relevant options in the Export menu above the file table.
It is not exactly a double-click solution, but it works.
#3 2022-03-07 01:34
nkormanik
Thanks for getting back, Dennis.  Excellent.  Glad you're still working on your programs.  Hope all is well.
