Several years ago I had asked about this, MOVING items, and the response was that ReNamer does not focus on moving.
HOWEVER, it was pointed out that, indeed, ReNamer was capable of moving items. By using slashes.
I don't remember exactly how.
But..., I'd like to again request the ability to move items, once renamed.
Case at hand:
On desktop. Rename a set of items. Windows rearranges icons making the renamed items hard to find.
Preferably, after renaming the items, ReNamer could put said items into a folder of user's choosing. This could be the final line of the code user runs.
Thanks!!
Nicholas Kormanik
You can simply insert the new path (absolute or relative) as a prefix to the new name, that's it.
See this article for additional information and examples: ReNamer:Renaming_to_another_folder.
How about THAT!
ReNamer just gets better and better.....
Hello, almost the same subject I didn't want to create a new thread.
I renamed my files to 001, 002, 999.
I need them to move to new folders by block of a specific number, let's say 10.
I want the new folder to be renamed with the name of the first file inside, 001, 011, etc
Thank you.
Hi Togolen8, welcome.
You know ReNamer is a tool to rename files and folders, not to manage your file hierarchy.
But ReNamer can do his work with the help of PascalScript,.... and with that you can do many things,
... we will see if we find a solution for you. But may need some time.
And, this issue will probably moved to an own thread, to keep things belonging together into separat places.
... we will see if we find a solution for you. But may need some time.And, this issue will probably moved to an own thread, to keep things belonging together into separat places.
I understand. I finally bought ReNamer after using it for years with very basic needs. I was curious, looking for something called a .bat file for my need and I found this post. Now I have to deal with 10s of 1000s of files and I use ReNamer a lot.
Thanks. I've bookmarked this post. I have another question, will create a new thread.
I want the new folder to be renamed with the name of the first file inside, 001, 011, etcThank you.
You may want to try this.
- create a backup of your files
- add twenty-two of your files to ReNamer as files
- add this PascalScript rule
( read more there > https://www.den4b.com/wiki/ReNamer:Rules:PascalScript )
If that works, try with the rest of your files.
Edit: block modified:
But, @den4b , I am lost again on terminating the whole script on error, I forgot how to do this:
Description of flow control statements:
Break; - Ends the current loop.
Continue; - Skips the current iteration of a loop.
Exit; - Terminates the current routine (function or procedure or, used in the main block of code, the whole script).
Please note: Exit works only on the current iteration (file) of the script, but the script will be executed for the next file again however.
Update after response of den4b:
For to stop the whole process and display an error message to the user, utilize "error()"
Error( ' your error message ' );
if (not WideDirectoryExists(TargetFolder)) then EXIT;
if (not WideDirectoryExists(TargetFolder)) then Error( ' your error message , script will end here ' );
Please help
I have comment out that part in the script below, so the user just have to be sure that the "TargetFolder" already exists.
2022-08-24 by Stefan
Purpose: COPY AMOUNT of files to a new created folder, named like the first file of every loop.
Additional: After every loop of "AMOUNT" of files, the next filename is used as the new folder name.
UserSettings:
Set the "TargetPath"-var to a wanted path. This whole path MUST EXIST beforehand! Use NO trailing backslash here!
Set the "AMOUNT"-var to an integer which shows how many files you want to copy at one loop, like here "10".
ModResult,ModRemainder:Word;
BasenameUsedAsFoldername:WideString;
TargetPath = 'C:\Temp\test';
AMOUNT = 10;
if (not WideDirectoryExists(TargetPath)) then
ShowMessage('Missing TargetPath which must already exist beforehand');
exit;
if (BasenameUsedAsFoldername ='') then BasenameUsedAsFoldername := WideExtractBaseName(FileName);
WideCreateDir(TargetPath+'\'+BasenameUsedAsFoldername);
//ShowMessage('COPY '+FileName+' to folder '+BasenameUsedAsFoldername);
//WideCopyFile(const FromFile, ToFile: WideString; FailIfExists: Boolean)
WideCopyFile(FilePath, TargetPath+'\'+BasenameUsedAsFoldername+'\'+FileName, True);
//Reset the BasenameUsedAsFoldername-var after every AMOUNT-loop using Modulo:
//DivMod(Dividend: Integer; Divisor: Word; var Result, Remainder: Word);
DivMod(GetCurrentFileIndex,AMOUNT,ModResult,ModRemainder);
//ShowMessage('ModResult: '+IntToStr(ModResult)+' ModRemainder: '+IntToStr(ModRemainder))
If ModRemainder = 0 then
//ShowMessage('AMOUNT-loop done, will reset BasenameUsedAsFoldername to none, so the next file will give his name to set the new BasenameUsedAsFoldername');
BasenameUsedAsFoldername :='';
if (GetCurrentFileIndex = GetTotalNumberOfFiles) then
ShowMessage('I am finished, should be all done?');
HTH?
THANK YOU! Sorting 100s of 1000s of audio samples will be a blessing, not hell. Lots of positive energy towards you and the team!
By the way... Do you have a script for dark mode? Kidding.
Break - Ends the current loop.
Continue - Skips the current iteration of a loop.
Exit - Terminates the current routine (function or procedure).
Please help
That is a correct description of flow control statements. You just need to remember that the main block of code is just another procedure/function, so you can use the "Exit" statement to terminate it.
Thanks for the answer.
It is an logical error by me.
Of course exit works, but only for the current iteration/file.
And of course the script runs again for the next file. That has baffled me
So I was in real looking for to break the script execution for all the rest of the files.
IF (a=1) THEN stop the whole script execution completely, do not continue on the rest of the files.
I could use a "do it only once"-routine, to show my error message only once,
but the script would still run for every file and just do nothing.
But is there a better way? Like an "emergency exit"
Again, this is the use case:
ShowMessage('Missing the TargetPath, which must already exist beforehand');
ExitScript; // < < < < < < < < < <
Thank you for making ReNamer.
