#1 2021-12-31 16:33
andreas
Read file name and change exif date
my images are always saved in the following format:
Renaming by a program changes the creation date.
Is it possible to take the date from the filename and save it as exif date?
#2 2021-12-31 19:58
Re: Read file name and change exif date
Yes, it is possible, but not with ReNamer directly. ReNamer is capable to reading the meta file information, like EXIF data, but not writing meta information back into files.
You can use one of these capable tools:
* ExifTool
* Exiv2
You should be able to find many examples online.
