#1 2021-12-09 09:33
qqkkrandom3721
How to rearrange these files?
2020-12-25.mp4(3).json
To:
IMG_1234(1).jpg.json
2020-12-25(3).mp4.json
Thx!!!!~
#2 2021-12-09 12:53
Re: How to rearrange these files?
The desired effect can be achieved with the Rearrange rule, with the following configuration:
Split using: Exact pattern of delimiters
Delimiters: .|(|)
New pattern: $1($3).$2
Skip extension: YES
The same effect can also be achieved with the Regular Expressions rule, but it will require a bit more expertise.
#3 2021-12-09 14:08
qqkkrandom3721
it works pretty well!Thank you~
tag:#GooglePhotos #json
Delimiters: .|(|)
Skip extension: YES
