#1 2021-09-01 14:42
AndrewRH
Rename the extension only (not in filename)
Is there a way to select just the file extension for a renaming rule?
My goal is to recursively rename all movie files extensions (I need to remove a trailing underscore) - without affecting the filename (most filenames contain one or more underscores).
Some rules have a tick box to skip the file extension but not one to select just the file extension.
Thank you in advance!
(I also sent an email to den4b support for this; and if that person here, then please accept apologies for double-ask!)
Subject adjusted to better fit the content
Original: Rename based on what in extension (not filename)
#2 2021-09-01 16:31
Re: Rename the extension only (not in filename)
File_name1_test.ext
File_name2_test_.ext_
File_name3_test.ext_
File_name4_test.ext__
File_name5_test.ext___
File_name1_test.ext
File_name3_test.ext
File_name4_test.ext
File_name5_test.ext
TRY:
https://www.den4b.com/wiki/ReNamer:Rules:RegEx
Expression: _+$
Replace:
[_]Skip extension
Explanation:
_+$
_ >> literal sign underscore
+ >> one-or-many of the expression right before (here the underscore)
$ >> match at the very end of the string
[_]Skip extension >> do not skip ext to work on the trailing underscores after the ext too
HTH?
#3 2021-09-01 18:27
AndrewRH
I'll try that! Thank you!
#4 2021-09-02 06:12
There is another way:
- add all files
- mark only those with extension "*.ext" plus with something trailing "*.ext*":
Mark by Mask: *.ext*
https://www.den4b.com/wiki/ReNamer:File … rk_submenu
- replace the extension on those files entirely by adding the three letter extension EXT newly:
New extension: ext
https://www.den4b.com/wiki/ReNamer:Rules:Extension
Additionally we could also create a PascalScript for that issue cool smile
There are often more than one way to perform it with ReNamer.
