Can the export functionality of the program be set as a parameter in command line mode?
I would like to have the names exported to the clipboard automatically.
Subject adjusted to better fit the content
Original: Export as Command Line paramter?
Which names? From where do the command line get that names?
How should that actually work? And for what?
You could also just use the command line tools of your OS like:
dir /b *.txt | clip
Or an dedicated Filemanger.
The new names after the list is processed. I can click on the export button manually but I was wanting this to happen automatically after they are renamed.
